help on big 3
Chevy214
ok, so i kno that ur suppose to connect one from the alt to the positive on the battery, one from the chassis to the negative on the battery, but what about the third wire??? some say that it's from the engine block to the chassis, and others say it's from the engine block to the negative on the battery.
Which one is it??? or can it be either one??? i would really appreciate the help
ok, so i kno that ur suppose to connect one from the alt to the positive on the battery, one from the chassis to the negative on the battery, but what about the third wire??? some say that it's from the engine block to the chassis, and others say it's from the engine block to the negative on the battery.Which one is it??? or can it be either one??? i would really appreciate the help
or you could do both!
=D
also to be on the safe side.
Chevy214
Chevy214
dallas, tx
robertoyoung08
