Help needed with my setup
Eddie2k
As i was home for a few weeks from college i tried to set up my sound system
Had it all wired up and working but it sounded like absolutely cr@p! :whatever:
So far i had 1 Db audio sub 1200wrms, 4ohm DVC(dont slate me for having db audio //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif )
Running from an Alpine MRD M1005 (It's only 500wrms @ 4ohm tho //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif 1000wrms @ 2ohms
Onto the comps at the front.
They are Alpine Type-S 6 3/4" 80wrms at 4ohm also
Powering these is a Sony Xplod XM-SD22X giving them 200wrms @ 4ohms
The problem is the sub is very quiet even at high volume from the HU, messing with the amp settings doesnt really make much difference until you change the Gain settings, then it just sounds awful!
Some goes with the comps. They sounded alot better when they were wired from the existing wiring from the factory speakers.
Could it be i need a better HU? Cant remember what it is but it's not too great
Any help would be much appreciated.
Its DVC 4Ohm, But i thought DVC subs had 4 connections on the subs? Mine only have 1+ and 1-
The sub is wired + to + & - to - to the amp
The components are wired from the amp to a crossover in the door builds
If its truly a DVC check your ohms if both voice coils are wired it should be either 8 ohms or 2 ohms (with 1 sub) If your multimeter shows 4 ohms of resistance then 1 of your voice coils isnt hooked up
Picture on wiring to 2 ohms
edit: Also make sure you set your gain correctly so since you max 2 ohm watts is 1k then your voltage between the postive and negative (ac volts) should be the square root(wattsXohms) or squareroot(1000x2)=44.72v
Eddie2k
Eddie2k
Scotland
Eddie2k
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
