help needed on wiring 2 amps (newbie alert)
robbie_turner
i have already fitted one small amp 2 my 6x9's however i now want 2 add another amp 2 power a sub. the thing is im not sure how 2 wire these things up. ie what size wire i need. i have looked at a distribution block but this cost abt 50 USD in the uk. if i wanted could i run another wire from my car battery 2 run the second amp
If you have 4g wire Just get a Distribution Block that is 4g to two 8g. that will split ur power to two amps. If ur amp has a RCA preout u can just daisy chain the amp for the rca signal.
I could get you a distro block and send it to you relatively cheap....PM me. The distro block is a much better way to do it rather than running a second wire.
robbie_turner
robbie_turner
Birmingham, UK
Apoc
    Jun 24, 2026
    Jun 24, 2026
