Help NEEDED! Amp and speakers
dbrum
Hi I just installed front and rear 6.5" JL coaxial speakers 50 watts rms. Right now I have them ran off my HU and want to run them off of an amp and also hook up a sub and run it around 300 watts rms. Would this KICKER ZX700.5 amp work for me? In my HU I have RCAs for only front and rear where does the rcas for the sub go? And lastly what size and type of wire do i run from the speakers to the amp? Sorry I am new to this and Help is appreciated.
Amp Specs:
1300 Watt Max Power Handling
RMS Power: 40 Watts x 4 + 200 Watts x 1 at 4 Ohm
RMS Power: 85 Watts x 4 + 420 Watts x 1 at 2 Ohm
Number Of Channels: 5
Signal To Noise Ratio: 95dB
Frequency Response: 20-200Hz
KickEQ Boost with variable gain up to 18dB centered at 40Hz
Boost, gain, and crossover frequency controls top-mounted
Visible protection indicator
"Soft-start" circuitry
24dB/octave low- pass crossover in hybrid sub channels
Differential inputs for noise elimination
Full-range remote gain control
Dimensions: 22-1/2"W x 2-5/8"H x 10-1/4"D
90 Days Kicker Warranty
dbrum
dbrum
tucson
dbrum
Mike Mccabe
