HELP! my system's sound is hanging in the BALANCED lol CD8053 w/ xtant 604x
2004alpinewhite
I have an eclipse cd8053.. It has the option to go to a balanced output.. I also have the xtant 604x and 603x.. Both accept balanced inputs.. So my question is this.. Is it possible to use the balanced line from the eclipse hu straight into the amp? Or is the balanced converter required? I also have an audiocontrol DQS equalizer.. So my question is also this.. Would I be better off just using one set of my rcas and run it through the DQS? I am unable to find the balanced line adapter anywhere.. If anyone has one, please let me buy it! haha
The balanced inputs on the xtants are intended to be used with a factory radio. IMO, the 8 volt output of the eclipse should be more than enough power to provide a clean signal into the amps. I just removed an 8V eclipse out of my car, that was running to an X603, and an X1001.
2004alpinewhite
2004alpinewhite
Evansville, IN
lashlee
