StupidLoud727
Audio Amateur
Alright I need some help figuring out my problem here, because ive been working on it for 2 or 3 hours and haven't heard a note out of my sub, although the amp is turned on and my other speakers are working.
So here is my setup...
I have a DVC 4 ohm 12" Type R wired to a hifonics bx1000d amplifier. I am trying to wire it to 2 ohms, which should give it between 400 and 500 watts RMS. I have it wired like so (sorry rough diagram ignore the periods solid lines represent wires):
......................... to amplifier + and - outputs
l....................l
l..............l banana cable between the two positives
.......l.............l banana cable between the two negatives
So do I have that wired wrong? I'm using 4 AWG power cable and the amp is turning on fine, my ground is working, and so is the remote turn on. I have the two RCA cables going to the line in ports of the amp, while nothing is in the line out. The speaker outputs on the amp are + + - - and i have the speaker cables to the sub going to first positive and first negative output. There is one other place I think I may have a problem.
Long story short, at the moment I cant put in an aftermarket head unit, so I kept it stock and tapped into the rear speaker cables instead. I used a unit designed to do this that is a box with two inputs for the other ends of the RCA cables from the amp, and 5 wires coming out between them. The right two are the positive and negative, so i tapped them into the positive and negative right where the wires go into the right side rear speaker, and did the same on the left side two wires. The center wire on the unit is an optinal ground, which i just taped to a ground point in the trunk. Did I do something wrong there?
I have no idea where the problem is, or how to set the 5 different dials on the side of the amp, which I dont think should keep the speaker from working at all if they aren't set right. I do have a gain knob that I wired to the driver's seat but since the sub isn't working I can't tell if it is doing anything. Thanks a lot in advance for the help. I stopped because I thought I smelled burning rubber...
