Help my fucing txi7508
if the amp is externaly fused id just hook the power to the amp with out the fuse just to see if thats the prob if u dont have a DMM. then ud know 4 sure if u needed another fuse. my brutus amp did that same mess the hifonics was lit half assed and no sound it was my fuse i had way to small a fuse and it 3/4 the way melted the bar. just a sugestion
sound like a bad idea. you should never hook up anything that is directly connected to the power source without a fuse. I say go buy a DMM for 20 bucks or so. Its a great investment and im sure you will use it later.
as for your fuse, you could find those fuses anywhere at pepboys, home depot, etc. as long as you match the fuse rating with the one you replaced, you are set.
i wasnt saying to run the amp full out just have power go though it and see if it has any output. if the amp has fuses on the outside there is not a prob one with doin it that way.
yes a DMM would be better and u could see what kind of voltage ur gettting from the sub output but u have to use AC power setting to read that
You could also call 847-540-7700 and ask for technical assistance.
You may not want to call it a "fucing TXi7508" when you are asked what model amp you have //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
coledawg
Where the Hell am I?
coledawg
Macon,GA
Team Maxxsonics
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
