Help my fucing txi7508
coledawg
Where the Hell am I?
So i got in the car yesterday to listen to music coming home from work and i wanted to turn on my sub reached down to turn it on and it says its on on the HU I then reach down to turn my bass knob up and its not on....WTF??? its the amp in my sig... Checked ground and fuses they looked fine??
the amp is only flickering on a little, but will not give any power to the sub
im not talking about the fuse on the amp. im talking about the fuse on the power wire running from your battery to your amp. If you have a DMM, i would check the voltage of your amp.
o ok the power wire fuse i checked it had like little spots and shit on it in a small spot and looks dirty so is that blown...
replace the fuse and see what happen. thats what happens to mines. I check the voltage of the amp and it read like 9v. so i change the fuse and it read 14v. I dont have a fuse cover for my fuse holder so dirt and grimes was getting on it.
see i had a fuse holder over mine and the little piece of metal was still dirty and fuses can be found pretty easy like if i run over to home depot or something or should i buy one online its a tsnami kit if that helps its a fuse that is round and doesnt look like a fuse in the amp
wtf...//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
if the amp is externaly fused id just hook the power to the amp with out the fuse just to see if thats the prob if u dont have a DMM. then ud know 4 sure if u needed another fuse. my brutus amp did that same mess the hifonics was lit half assed and no sound it was my fuse i had way to small a fuse and it 3/4 the way melted the bar. just a sugestion
coledawg
coledawg
Macon,GA
Team Maxxsonics
