help me with a remote for amp.
my jeep has a factory amp and power antenna so you could just tap into that. also tap into the accessory wire. this maybe a dumb question but couldn't he run a remote wire directly from his battery and wire in a toggle switch to shut the amp on and off? i know it wouldn't be easiest but for shits and giggles would that be possible?
Well I would like to tap into my 12v switch that goes to the deck but I am unsure of witch one that would be. I would guess it would be red. I have a meter and some other equipment that might help me to determine it without cutting any wires.
As far as the signal I am planning on getting a nice LOC
I just thought of a couple of things. I have a DVD player in the center console for the rear seat. Is it possible that it will have some sort of remote that turns on with the vehicle?
T-Bone, What kind of jeep do you have and were is the factory amplifier located on it
it's a 95 grand cherokee and the amp is under the left rear seat. the lead wire hooks into the stock headunit inside the dash.
Problem solved. I am the DVD remotes off of the HU. I will just tap into it which will be alot closer to were the amp will be. Now I will just have to tear into it and figure out which one it is
phoneman
i like pie
phoneman
ok
Chika-Boom
