Help me please!!!
  • Thread starter Unregistered
  • Start date
  • Replies 3
  • Views 611
  • 2
U
Unregistered
Guest
I'm a beginner when it comes to car audio so could someone answer this for me... If an amp is 1500 watts x 1 at 2 ohms, could you power 2 subs with it or just one??? If it is 750 watts x 1 at 4 ohms how many subs can you power with it??? Help me please!
You could power as many subs as you want.
1500x1 means the amp will dish out 1500 watts into one channel. You can feed that to however many subs you want. The wattage will be shared among the subs though, so if you have 2 subs, each sub wont get 1500 watts, more like 750 each.
Watts or ohms have nothing to do with how many subwoofers you can power, but with how much power each sub gets.
unregestered- watts and ohm has a lot to
do with how much speakers and how much watts/power
each speaker will get at various speaker loads ( ohms)
for example 1--1500.1 amp at (2ohm mono)
you can use-1svc 2 ohm sub for 1500 watts to that sub
or 2-svc 4 ohm subs wired in parallel for a 2ohm load
each sub will get 750 watts each
or-2 dual 2ohm subs wired in series/parallel for a 2 ohm
load. each sub will get 750 watts each
or 4-- 8 ohm subs wired in parallel for a 2 ohm load
each sub will get 375 watts each.
or-1-dual 4 ohm sub wired in parallel for a 2 ohm load
that sub will get 1500 watts
just make sure that the subwoofers that you are planning
to use can handle the watts/power at these loads.
hope this helps you
Also to add to the post above mine, if you plan on running 2-ohms or lower, make sure your amp will be able to handle it. If I am correct, with the specs you supplied, I think you are talking about the bd1500, and that is stable down to 2-ohms.
987
The sound deadening is going to be more about preventing vibration from metal surfaces and adding unwanted noise. Does it have the JBL system...
It's called the K.I.S.S. preciniple ("Keep it simple, stupid!")... Takes the guesswork out of parallel/series wiring.
937
As for which signal to use, I tried all combinations and getting signal from the dash and front & rear doors is the only way the system sounded...
15
Guest
Phatillusion
    May 12, 2024
Brendon Jenness
    May 11, 2024
