Help me pick out an Amp for my Mojo
And? If they want to play over 40hz u would adjust your LPF not sub sonic. Sub sonic is so u don't play to low/ to far below tunning to bottom out/damage a woofer.
The reason you don't need one is because you tune so low. If you tune to play more bandwidth flat you can't tune as low so you need a sub sonic.
This is basic stuff
This is basic stuff
30-33hz tunning isn't low for daily. I can play 50hz 60hz 70hx just fine with my woofers and still murder 20hz... Sure it's gunna drop off alittle in the higher range but it still plays every note just fine. This is basic stuff
Ever put it on a meter to see what its really doing? The higher the frequency gets the louder you think it is. Pressure will tell you how high it really is. You know what happens when you start playing this game with me. Port area is a determining factor also. That's how prefabs can go without a SS because they don't enough port area to matter.
Also moving some air isn't murdering, that's just cones moving.
Also do you know how slopes on crossovers work?
Where in VA are you? I know 2 DD dealers that might be able to get you a good deal on a M1. Those put out power.
I live close to Bristol,VA. About 45 mins away NE from there.
Check out Bryant radio but there is also a dealer in Bristal. Go with cash in hand and work out your price.
I would put a M80 up against that 1200
Now which amp am I getting for that amount of money? I never heard of Of that place, thou.
Go with the sundown. If anything happens to the DD, you may have a hard time getting them to warranty it.
So walking into a dealer is harder than sending the amp yourself and paying shipping? Sounds dumb
---------- Post added at 07:15 PM ---------- Previous post was at 07:14 PM ----------
Might be able to get a M1C if they have any left to clear out.
Bryant is a shop that holds all the MECA events in Va.
Where at though?
JJ_Stin
JJ_Stin
VA
Jeffdachef
