DarrenE46
I have narrowed down my choices for a class-D budget mono amp. The amp needs to be less than $150 shipped and must produce at least 300W @ 2ohms. The amp also needs to be digital since I am running this in a 2001 Civic that has a weak stock alternator. The amp will be powering a CDT HD-1020 subwoofer in a ported cabinet that will probably be 1.3cu ft @ 32Hz. The sub is 400W RMS and 800W peak. I don't need to pound the sub I just want a cheap amp that will get the job done. What do you guys think?
1. Directed D600 $80
600W Peak
RMS Power Output:
200 watts x 1 chan. @ 4 ohms
300 watts x 1 chan. @ 2 ohms
2. Kenwood KAC-8103D $90
1000W Peak
RMS Power Output:
300 watts x 1 channel @ 4 ohms
500 watts x 1 channel @ 2 ohms
3. MTC TC3001 $100
900 Watts max
150 Watts RMS x 1 @ 4 ohms
300 Watts RMS x 1 @ 2 ohms
4. Kicker ZX400.1 $100
200 watts RMS x 1 at 4 ohms (400 watts x 1 at 2 ohms)
400 watts Peak x 1 at 4 ohms (800 watts x 1 at 2 ohms)
5. Power Acoustik REACT1-1100 $90
4-Ohms @ 300 x 1
2-Ohms @ 400 x 1
Power Handling (MAX) : 1100 Watts
600W Peak
RMS Power Output:
1000W Peak
RMS Power Output:
3. MTC TC3001 $100
900 Watts max
4-Ohms @ 300 x 1
2-Ohms @ 400 x 1
