Help me order some wiring ....
Schnitzel
Gunna be running a Skar sk1500.1 amp for my 2 sundown audio sd8s and an arc audio xdi 600.4 4 Chanel.
Was wondering if you guys think 1 run of 0 gauge OFC wire ran to a distribution block would be enough for these two amps? Skars website says it recommends running a 0 gauge wire to that amp, and the arc recommends a 4 gauge.
Planning on going with all KnuKonceptz wiring
Also what wire should I order for speakers and subs? (What gauge? And how much). And what about RCAs?
It's going in a 4 door f250. The Amps will be installed under the seat.
Any help is greatly appreciated. Thanks guys
Just do a run of 0 gauge into a block, with a 0 gauge run coming out to your Skar and a 4 gauge to the Arc.
As far as speaker wire, i generally use 12 gauge or bigger for anything over 1000 RMS. 16 gauge works for mids and tweets. Maybe slightly bigger if you're running beefy mids.
RCA's, just get a decent pair.
If you feel the comments above are not aceptable to your own thoughts and would like a for sure route.
You can do a dual 1/0 gauge input distribution block with 2 1/0 gauge "CCA" (cost effective) or OFC (costs more but better for future).
With that you can either get max amperage of 500 amps with CCA or 600 amps with OFC.
This will leave room for future amp upgrades.
Sent from my Z970 using Tapatalk
Yes, you should be fine.
I've and a few guys tell me I would be old doing it this way, so I think it should work. Thanks for your input. Gunna order the wiring right now.
The only issue is I don't have room for upgrades. The subs I'm running are maxed out on size. Otherwise I would agree with what you saying. Thanks!
Here's my list. Probably would have saved money if I went with one of their amp kits, but I wanted black power wire so it didn't stand out. I also wanted the nicer RCAs, so buying the amp kit didn't make sense.
Schnitzel
Schnitzel
Corona CA
Schnitzel
