2006 Acura TSX New System Installation
eleceng20
Hello all,
I have a 2006 Acura TSX w/o navigation. I have elected to keep the factory head unit and am looking to take my car sound to the next level.
Currently installed my Acura are:
4 - 6.5 inch JBL GTO638 3-Way Coaxial Speakers (in the doors)
2 - 6x9 Infinity Kappa 693.9i 3-Way Coaxial Speakers (in the rear deck)
2 stock tweeters(will replace in the future)
Factory Head Unit
I am looking at purchasing the JL Audio CL441dsp CleanSweep processor and adding an amp, but I am not sure what amp to purchase.
I would also like to know what amp should I get that will work well with the Clean Sweep processor and also connect to my door speakers, rear deck and possibly a subwoofer in the future. I really like the solo baric l7 woofer.
Also, I am installing Peel and Seal as a sound deadener in the car. It is working very well in one of the doors that I have finished and also underneath the rear deck where I had some significant rattling.
Any help is appreciated,
Thanks.
Specs for Speakers:
JBL GTOs
Nominal Impedance2 ohms
Sensitivity(2.83V@1m) 92dB
Power Handling (RMS)60W
Frequency Response50Hz – 21kHz
Power Handling (Peak)180W
Infinity Kappas
Sensitivity 95.6 dB at 2.83 volts
Frequency Response 35 - 30k Hz
RMS Power Range (Watts) 2-110
Peak Power Handling (Watts) 330
Impedance (Ohms) 4
Top-mount Depth (Inches) 3 5/16
Bottom-mount Depth (Inches) 3 7/8
You need to slow down. You are going at this way wrong.
The clean sweep only resets the factory EQ it gives you no way to retune anything except a few presets. Bad idea.
You have way to much going on inside. One good set of components amped and installed right is all most anyone needs. No 3 way coax mess.
Kicker is getting to the flee market quality these days.
Start with a budget and go from there.
eleceng20
eleceng20
Atlanta, GA
eleceng20
