okay man, we told you what was good, and what isnt.
get the raamaat.
I put a SHITLOAD of edead deadining in my explorer, which did okay.
but, two rolls of raamat and 7sq yards of ensolite in my new ride absolutely destroyed the edead.
the raamat is the best bank for the buck for sure. you wont regret it.
Do a layer inside the door, a layer on the door to seal all the big holes up, and a layer of ensolite over the top, and you will see a huge improvement.
People told you the options you should look at.I am going to be soewhat blunt here. I haqve used some of the other products out there and there is NO comparison to Second Skin, the closest thing to it would be Dynamat although the Second Skin has a thicker foil backing which I like better but both of those are the best on the market period the end. You mention doubling up with some other products, now consider that for a second. Your willing to double work for the less than the same results? You also run into the very serious potential of it falling off in 6 months as well, trust me I need to redo my doors in my truck because 70% has come off because I also thought your way at one point. I put 400ft (yes NOT a typo) of SS in my car and it is still rock solid nearly a year later. about a month after using deadener "x" in my truck I applied SS to the back wall and with "x" all falling off, the SS is still rock solid on the back wall. Spend the coin now for a superior product.
"Rubberized compound" is just a dishonest way to describe asphalt. All asphalt roofing products have rubber added, it doesn't make them butyl or anything other than asphalt. FatMat used to claim on the Web site that it was butyl. They got called out on that. Instead of outright lying, they agreed to to just be misleading //content.invisioncic.com/y282845/emoticons/wow.gif.23d729408e9177caa2a0ed6a2ba6588e.gifyea well i read asphalt based deadener is bad well the fatmat i read is a rubberized compound on their website so how is that stuff so bad and it has 100% money back guarntee
and the b-quiet extreme is a ruberized asphalt isnt that the same as raamat, also i have the speaker piece of the dynamat original in my truck came factory just a small piece 12"x12" and its pretty thick and has always stuck to the door panel very good its the rubber asphalt material hows that stuff
