help me make a wise decision
promerexp
4
lv
i just bought 2 type r but i need an amp to power them, i recently got 2 prs-d3000spl amps (500@ 2 ohms 1000@2 ohms), but i want something better, so my choices re:
a) mtx ta8001 1500w @ 1 ohms
b) 2 mtx tc8001 800w @ 2 ohms
c) 2 mrd-1005 1000w @ 2 ohms
d) usamps m2d 1800w @ 1 ohms
e) any other you recomend
also budget is 500 i know that c is a little expensive but if its worth it who knows
thanx 4 your help
Good best way to run subs besides 0.5 Ohm. You can run your 2 type-R's at 1 ohm and you will get the most power to your subs with what ever amp you chose provided you get a 1 ohm stable amp but these days most of the amps are. Good luck! MRD-m1005 are hella good amps too! Little $$ though!
Hey 406er , you build boxes for in spare time or professionally? Also I see your in Winnipeg and im in Fort Frances so if your interested I would like to talk about a potential box build? Lemme know if your interested!
yeap i know that i can drive them at 1 ohm into 1 amp or at 2 ohm in 2 diferent amps, but my question is what will give the best results?
i just bought 2 type r but i need an amp to power them, i recently got 2 prs-d3000spl amps (500@ 2 ohms 1000@2 ohms), but i want something better, so my choices re:a) mtx ta8001 1500w @ 1 ohms
thanx 4 your help
Quite frankly I don't see why you don't use what you already have and not spend anything?!?
The PRS-series Premier amps are rock-solid units without a doubt.
Since you've got a pair of D4 subs and a pair of amps that makes more than adequate power @ 2 Ohms....umm....1 amp per 1 sub and call it a day?
If you're just itching to give money away I'll be more than happy to provide my PayPal payment email, though...
promerexp
promerexp
lv
Prowler573
