help me got a pontiac g8
07sciontc
memphis and sundown
this is one of thoses rides with the buil in dashes i want a system has a stock woofer in the front dash blown and it ***** *** lol i wana know if i can use the hook ups off the stock woofer and if there is a amp replce it with a big amp and subs in the truck thanks for any help
the speaker in the middle of the dash is not a subwoofer. Get a line output converter, and hook it to the rear speaker wires that go into the stock subwoofer amplifier in the trunk
i have seen the stock woofer mounted in the front in a tahoe bose system. if you are sure it is just a sub, then ot will be a lp crossed high level signal, which means you need to get a loc and tap to it, or use the high inputs,if equipped on your amp. usually, if it's a single driver, than yes, it is the factory sub.
the honda element has a stock 6" sub up front but its more or less under the dash. if your speaker is in the center of the dash, like by the windshield, its probably a center speaker and not a sub.
I have recently purchased a 2008 Pontiac G6 with the Monsoon stereo. We want to keep the the display functions of the stock headunit so a quality converter was needed.
I installed a re-Q5, and am very pleased with it.
re-Q - Take control of your factory stereo!
The re-Q5 version converts your Highs, Mids & sub outputs to an A/V output. It also has adjustable gain control. I paid about $90 off Amazon.
If you have the monsoon system, I recommend you splice into output signal from the Monsoon amp. I tried splicing into both the input & the output wires, and the OUTPUT provided better volume & sound quality. (at least to my untrained ear )
07sciontc
memphis and sundown
07sciontc
Hotsprings,va
Jasonc13
Mike Mccabe
