Help Me Get MORE BASS PLEASE!!!!
focused313
Learning With Every Post
Ok, I'm absolutely going CRAZY at the lack of bass in my 07 Charger. I didn't want much bass in it (I also have a magnum with 3 JL w3's in it and that's perfect), but what I have now in this Charger is absolutely pathetic. I can barely hear it.
Hifonics BIX608
300w @ 2ohms
600w @ 1 ohm
Sub
JL w3v2-4 wired @ 2ohm load
Ported Box
Please help me choose the best option to get more out of my system for the least amount of money/hassle:
1. Get a new dual 2ohm sub so I can get 600w out of the amp.
2. Get another w3v2-4, a new box, and wire them for a 1 ohm load.
3. Scrap the w3's, get a new box, and two dual2ohm type R's.
Does the seat lay down?
There is probably a thick mat of insulation behind the rear seat
yea I saw that today. Not to mention there is a layer of deadening on the top shelf where the 6x9's are. The seat doesn't lay down unfortunately.
as for the mtx......no
2000w RMS.........no, lol
I'm almost tempted to put the subwoofer in the back seat, lol. If I didn't have my magnum to rely on, I'd be going crazy
remove the insulation!
you need more power, or same power with more cone area and efficient subs!
300w on 1 12 wont get very loud
Get another jl and wire them up to 1 ohm in a nice ported box=done.
That setup is capable of getting decently loud... You should remove the speakers from the rear deck before you try anything else.
Not only are the 6x9's there, but there is a casing below the speakers, then insulation on the top side of the shelf.
I'll remove the installation first. Then remove that bottom shelf, followed by removal of the 6x9's.
If that doesn't work, I think I'll just go straight to adding another JL and another ported enclosure. Darn it I hate when I don't just do stuff right the first time. smh. //content.invisioncic.com/y282845/emoticons/verymad.gif.3f39c5c2fd57527b671fad3efdfac756.gif
focused313
focused313
Michigan
focused313
