help me fix my voltage drop
i think i have a 60 on the pdx. thats enough.
the sub has 2 power inputs so i have 2 4awg wires running with 100amps. gives me a 200amp fuse. its an AGU disrto block so i cant go any higher.
huh? you just said you know im running stock up front but what am i running up front? uhh stock up front. acid battery.
from the front battery to the amp the - wire read .1ohm. so that shouldnt be doing anything.
im thinking that its the car. i think the regulator for the alt is just slow. ill look into the MLA to test that.
when i bought my first HO alt, it worked good for a minute then the regulator went out. i didnt suspect that was the prob, but after testing everything else realized that was the prob, got a bew one and all was fine...
your problem is very easy to diagnose... somewhere in your electrical setup and wiring, you have done something wrong or you are having equipment failure at the batt or alt level. Plain and simple, unless you have some crazy issue such as exposed wires grounding out a bit or dumping part of your voltage to part of your car.
skittlesRgood
skittlesRgood
fremont, ca
skittlesRgood
