Help me find a battery teminal plz...
hurseyc
I've looked everywhere online and can't find what I need. I'm hoping someone on the forums has something like this or knows where to get one.
I need a top post battery terminal with two 0 gauge connections as well as a couple of smaller gauge connections.
I need one 0 gauge for the run back to my amps and one for the Big 3 connection to the alternator.
I need the two smaller connections for the two stock wires that came connected to the battery in my Expedition.
Any help would be appreciated. Thanks
I've checked on http://www.knukonceptz.com and at Parts Express and at Metra and just can't find a terminal with what I need.
If you know of one with all the connections I need please post a link.
My next option is to convert all 4 connections to ring termals and buy a post to ring terminal adapter. I don't think this will look very clean though.
Thanks
get the PE ones.... you have one 1/0 going in the side with a set screw, the you have one on a ring terminal up top, the you also have a 4 guage hole to put both of the small wires in... if that's not big ehough throw another ring terminal on top.
i don't see why that knukonceptz won't work. 1/0 gauge set screw, ring terminal on top and smaller set screw inputs.
KnuKonceptz and PE are the same, but PE is cheaper I beleive
http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=263-677
http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=263-678
VS
http://knukonceptz.com/productMaster.cfm?Category=Battery%20Terminals
I'm biased though, i live 20 minutes away from PE HQ and am currently about 5 minutes away from there only other store.
How about this. Two 1/0 inputs and One 4 AWG. Or this is a little cheaper, this just has 2 1/0 AWG Inputs. 2 1/0 Gauge. If you need more stuff while you are there you can spend $200 and you will get free shipping and 5 dollars off using the coupon code CARSTEREO.
wow $36 to do the same thing or less than the $6 terminals I posted.//content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
You're a crazy guy.
You can pick up the tsunami battery terminals from Autozone and just drill the holes out. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
It originally comes as a dual 4, dual 8 in
I drilled the holes out (actually, not even the entire hole, just the inside where it steps the size down) and turned it into a dual 1/0, dual 4 in.
That is, if you have the tools to do that. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
You're a crazy guy.
Just trying to help the guy out he was saying he did not like some stuff up top so I figured I would throw a few more things out there. He can pick which ones work for him the best. Not trying to jump over top of you or anything, sorry about that.
hurseyc
hurseyc
St. Louis
hurseyc
vegang
vegang
