help me design a box for 2 ssa xcon 10 inches for daily
Abo raya
Hello guys
Can you help to design a box for my subs, here is the info about what I want
Subs : 2 (ssa xcon dual 2) 10 inches( 2017 model). Here is the ts parameters
· FS: 37.9
· QES: .38
· QMS: 5.3
· QTS: .35
· SD: 310
· VAS: 8.4L
· SPL: 82.7
· BL: 15.74/22.25
· RE: .7 ohm / 1.4 ohm
· MMS: 279
· Xmax: 29mm
· RMS: 2000W
Sub amp : 2 zapco st-2000xmii strapped at 2 ohm
Car : yaris 2010 sedan
Box location : in the trunk with sub and port pointed toward the cabin because I wanna sealed the box off
Space available : I will have a weird shaped box because I have to have access to batteries the net available space inside the box is 5.8 cube.
Rear seat: I have 3 rear seats. I can fold one seat behind the driver seat or I can fold the middle and the one behind the passenger together because they are attached and of course I can fold them all
Electrical : 1 singer alt 320 amp with 3 acid batt of 250 amp combined
Bandwidth needed : from 25hz to 50 Hz minimum. The wider the better especially on the lower side but if it will comes at the cost of achieving the goals over the needed bandwidth then I don’t want it
Goal : daily system with clear clean accurate sounding bass, extremely loud across the bandwidth while murdering the hell out of the lows especially 32 hz and below
Type of music : I listen to every type of music. Rock, jazz, pop you name it and I listen to a lot of slowed music . decaf djsnt and such
Proposed box : based on ssa recommendation and my little knowledge and the space available I thought 3.5 cube tuned to 31 with 60 inch squared of port area or 3.5 cube tuned to 28 with 52 inch squared.
I have graphed the tow boxes in Bassbox6 pro. The yellow graph is 32hz box, the orange is 28hz. here is the result
https://imgur.com/a/qMMou
This is the typical response and as you can see the 28hz box have an advantage over the other box from 30hz and below which is really what I want.
But
Here is the response when I apply the port resonance
https://imgur.com/CETIEWv
As you can see the 31hzbox is louder from around 27hz and up over the other box . which if it was true I will do it
My questions : is my tow proposed designs are going to help me achieve my goals and if so which one of them
Is the port resonance predicted by the program true
Where should I place the port ( behind driver seat or passenger seat or in the middle ) the port is slot
If my proposed designs are wrong what is your recommendation based on everything I mentioned
Any help is appreciated and if there is anything you want me to add please tell me
I hope I covered everything needed and thanks in advance
60 is like 17^2, which in my experience is a pretty sweet spot for daily builds with drivers that have good excursion.
Thanks for your help man
After i did some calculations i came up with 3 options
3.5 cube tuned to 28hz with 52 port area
3.5 cube tuned to 30hz with 60 port area
3.5 cube tuned to 32 hz with 70 port area
So what do you think will help me achieve my goals better
Thanks in advance
Really appreciate your time and help
i like higher tune for volume and cause i like rock music but tuning up to u.. but i wouldn't do 70 sq in port unless u modeled rear port air velocity at your clamped power and it showed u need that much port..
I've used that driver and the ported box is closer to about 2 cubes. We did 1 in a stuffed/sealed 1-1.25 cubic foot box, stuffed with 1 lb of...
731
People didn't like ported boxes because the port noise and needing a bigger box. Therefore, instead of 1-sub in a ported, they would go with...
30
In the meantime you could stuff that port hole with a blanket or some pillows and it would probably sound better, if you want to listen to some...
Buddy of mine somehow managed to get small MDF boxes set into the rear doors on his previous truck, think it was an F-150. I can't remember...
988
Abo raya
Abo raya
Los angeles. CA
denim
    May 19, 2024
    May 18, 2024
