Help, is this design right ?
hks
20
aaa
does this came out to be 4.7cuft 37Hz //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif port is 13.5x4
but the port is just 1.25'' from the back wall //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
can this box be use ?
can anyone help if this design fail.
40w x 20d x 15h is the max i can go
each port should only be two inches wide after it splits.
I just meant if he wasn't going to have it split into two different ports. But I guess since the port's in the middle you can go half the width from the back since you'll be getting air flowing into the port from each side of the port. I'm used to doing potrs on the side so I've gotten a little rusty when it comes to splitting/center ports.
yea with it in the middle it splits into two separate ports which have to combine to make the main port opening
wasn't callin you a tard or anything I'm sure you know you're stuff just a mistake //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
I'd make the port a little skinnier (down to 3.75) so the port's longer to lower chances of port noise.
Que?
hks
hks
aaa
Rashaddd
BP1Fanatic
BP1Fanatic
