!!!!@HELP in ChoosinG the Best HU@!!!!
  • 4
kickyaazz
hi..im looking in buying a HU..and i was wondering what do you think..which one is the best from this 2:
JVC KD-R401
Pioneer DEH-2200UB
and i have 1 more question:
i saw that the jvc has 4X19 W RMS with THD below 1% and RMS Power Bandwidth: 40HZ - 20000HZ
and the pioneer has 4x22 w RMS with a tHD of 5%..and at 4x14 W RMS(all channles driven) has 1% THD
and the pioneer has a RMS Power Bandwidth : 50hz to 15000hz
this specs are from the manuals!
i dont know..maybe the pioneers specs are more accurate ..
SO which one should i choose.Thank You
Pioneer units used to be one of the best. I have one of the lower end UB-1200 or something ($70) unit laying around and its OK. Personally, I've always liked Eclipse, Kenwood, JVC, Alpine - in that order.
yea but...the output power..is almost the same? i've googled this hu too: eclipse cd3200 and it says that this has only 4x 14w RMS too (CEA -2006 compliant..dont know what this means. It says the same in the pioneer manual...14w X 4 at THD not more then 1% CEA -2006 compliant but in the JVC manual doesnt say anything about CEA -2006 compliant...it just says 4x19 W RMS wiht a THD of 1% MAX)
The CEA compliance was put in place to have a standardized form of testing. The amount of gross exaggeration and lies in the car audio world made it necessary to come up with a standard everyone is supposed to follow to make it equal.
That being said, you really wont hear a difference of 5W per channel. If you want it louder or sounding better, look into running at least a 50W RMS per channel amp to your speakers. Head units can't dissipate enough heat to handle more than about 20W per channel RMS. If you need more, you need an amp.
Your image doesn't really show anything. That could be 3 different head units for all we know, but I think it's 2 different add-ons. It sounds...
979
You can Email or Call GP Audio and they can make some adjustments to make the enclosure shorter and either deeper or longer on the Glue and screw...
114
9K
Not at all, amplifiers have gain control to attenuate the output to safe levels.
I've moved this post to installations. Can't work out how to delete it here.
kickyaazz
kickyaazz
Los Angeles, CA
kickyaazz
    May 18, 2024
    May 18, 2024
