Help!!! I need ported box plans.. have money!! ASAP
rregl
21
Pa
I had a box plan but fubed up and ordered a 12 instead of a 10.. so now i have to start at square one..
I have a diamond audio D612.2 that needs a new home.. it will be shoe horned into the trunk of a 240sx coupe..
Heres my dimensions.. 13in high, up to 28 wide and up to 20 deep.. I will be making it out of 3/4 mdf. and have a router to round all port edges.. and 45* wedges for the corners
if you need more info pm also I can spend some moneys on this.. but I'm not looking for extravagant just for good sound..
speaker dimensions are as follows:
total dia 12.4
mount dia 11.1
displacement .10 ft3
Thiele/small parameters
Spl 85.5
RE series 3.9 probably doesn't matter but are being run in series..for 4
Qms 5.24
Qes 0.53
Qts 0.49
FS (hz) 32.4
Vas (l) 12.6
Cms (mm/N) 0.070
MMS (g) 346
Sd (m2) 0.049
Bl (T*M) 22.1
Xmax (mm) 17.8
pwr nom, max 600/1200 this sub will see 400 daily.. maybe if I upgrade later.. 600 never more!!!!
as suggestion only they show these stats for a ported box
vb (ft3) 1.25
Fb/F3 (hz) 40fb/34f3
port (in) (dia x lenght) 4X20.5
pe (w) 800 remember above..^
Will be in a sub forward port forward configuration and prefer sub on drivers side with port toward passenger..
or if you want to have it open in one page can be found here!
http://www.diamondaudio.com/manuals/d6_subwoofer_tech_sheet-2008.pdf
I will be checking pm's all night.. lets make a deal.. I got paypal standing by..
i built a box using the re calculator.. I don't think it was all that good.. or maybe I should rephrase that it was good but I think it could have been better...
rregl
rregl
Pa
rregl
michigan born
    May 14, 2026
michigan born
    May 14, 2026
