HELP? hiding amp wires and RCA
Guyver
For a 2011 Camry, where should I hide my RCA and amp wires? I was thinking about taking out the whole seat and carpet inside but it doesn't seem right. There should be another easier way around for a clean installation. The system has been set up inside my house for a couple of days now but where do all you car audio experts hide your wires?
Well....
Where are you mounting your amps? If you're mounting them under your seats, cut a slit in the carpet under seat, tape wires onto 3 ft ziptie or similar, pull up carpet by firewall, slide ziptie with wire under carpet to slit, and pull through. power wire on one side, speaker wire/RCAs at least 18" away
Guyver
Guyver
St. Paul, MN
Heeltoeclutch
Mike Mccabe
