Help!!! fuse to 12v battery keeps blowing!!
Padre619
So I recently purchased and installed 2 sundown audio sa8 v2s with a sundown audio sae1000d. The problem I have now is that when I play the music really loud for more then 15 minutes the 60 amp fuse I have to the battery keeps blowing out!! I have a 2 farad cap as well. Everything is good until I play super loud for more then 15 min. My wire to the battery also melted a little bit. Help!!
I had similar problem moving up to 1000RMS, I moved up to 150 amp and haven't had a problem
You cant just step up to any fuse rating you want.
The max fuse rating has to be the max rating for the wire you have.
Putting a fuse to big for the wire will cause a fire/melting/arc. The amp its self will burn if it does not have good protection.
Sent from my Z970 using Tapatalk
Thanks guys for all the tips. I'm running 8 gauge wire and had a 100 amp fuse and that blew out first. Then went to 60 cause that's all they sold at pep boys. I don't have pictures but the wire to the fuse box going to the battery melted in half. So you guys saying bigger wire and fuse?
Yes do 4 gauge (ofc if possible) and get anl fuse holder with a 150 amp anl fuse.
8 gauge CCA is rated 50 amps8 gauge OFC is rated 60 amps.
Lucky you didn't burn your car to the ground.
You need OFC 4 gauge and fuse to 150.
**** I know right haha. Well I'm a noob to this so I honestly didn't know better. These 2 little 8s do push a lot of power and sound awesome! Thanks again guys and I will be doing an update as soon as I get the new wire and fuse
Padre619
Padre619
San Diego, CA
audiobaun
