Help from the Experts!!!
hellraiser
Slayer
141
WI
Heres what I have, for a HU I have the Kenwood X979, I have rockford speakers in the front 4/6's, and 6/9's rockfors in the back deck(1990 Caddilac deville btw) and in the trunk I have 2 10" L7's in a vented box. The 4 inside speakers are being run off a Phoenix Gold 505 4 channel, and the subs are wired to 1 ohm and are being run by a Hifonics 1500D mono amp, seems the subs sound like crap, just wondering if I went big enough on the subs to rumble through the trunk up to the rest of the car?? Thanks
Are you positive the wiring inside the box & to the amp is correct? Also is it possible the port is tuned incorrectly? Could be a number of factors effecting performance... 1500watts and 2 10s should be plenty for some body shaking bass! //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
It's wired correct, checked it several times, It hits, but I had some L5's that were 12" about a year ago that made these sound cheap!
What kind of box would we be talking about?
dude...yu must be doing sumthing wrong 2 10l7 on a 1500 mono block should be enough....make sure your h/u settings are set up rite.....i got a 12l7 in a ported box wired to a 1000w mono block and it sound reall good..so urs should sound better and louder..
Some specs on box, I listen to more Slipknot, Korn, that type and some rap!!
100% Airtight Guarantee
Sealed with several different non-toxic, EPA approved sealers __ glue, staples and hard silicone
3/4" American MDF Wood
dado and rabber mating
top grade charcoal carpet
directed from factory
large slot port ventilation system
Two gold terminal
dimensions:32"width x 17 1/8" depth x 12" height
Cutout:9 1/2
Cubic feet per chamber: 1.35
~Designed for High SPL~
~Deep Low and Powerful Bass Response~
~Air Space 2.7QFt~
^ it's your box some ported boxs do sound like that some songs will sound grate and some will sound like shit thats what you get with port at lest i did ....good luck
Would a sealed box, and what kind, would be better? I new to getting into the shit on this stuff on a box, just want something that will pound!!!
hellraiser
Slayer
hellraiser
WI
Polecat
