help finding alternator...
My shit works just fine.I guess its your personall experiance.Maybe a bad one but it isn't a scam.And I don't see him telling you he knew it was broke before he sent it to you.If he did he still sent you another one right.If it was a scam he would have took your money and said FU@K YOU what you gonna do after the first alt.***** all you want but it ain't a scam!He has been around just as long as most of the other companies that make HO alts so I don't think he's scamming anyone.Does shit happen,is his CS a little slow,YES.But he has tried to work with you on this whole situation.He doesn't HAVE to give you a refund.
bottom line of the story dude, i NEVER recieved what i was sold... and after it became clear that he was not going to be able to provide me with what he was supposed to, i asked for a refund and he refused.
would be the same as if someone on here sold you something and gave you something different. that is exactly what happened to me. and he has even said on this forum about the first alt being sent DOA and he knew it was most likely DOA. he claims he didnt know enough about the alt and figured it would be fine. then after multiple other failures within literally 2 months use he made other promises to try to correct the situation. those were lies too. he never followed up on anything that he promised to do, including the original sale...
I have a 02 dodge neon SXT and i haven't been able to find an alt, well i did but he wants 650 bux for a 200a @ 2000rpms and 160 @ idle. right now i'm running 1 bxi2006d and a alpine mrv-f450. or if anyone has one used that they're not using PM me plz.
I could sell you my alternator off of my 04 dodge neon, its a 200amp iraggi direct bolt on. It was on my neon till I retired it it has approx 3,500 miles on the alternator.
pm me if your interested.
egg
egg
What!You have an Iraggi alt and it works?It can't be so!Hoss had me believe that Dominick was a scammer and only out to rip everyone off like he did to him.I can't believe you bought one...............:eek:J/K
lol yeah I know what your talking about //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif BTW, I have 3 Iraggis that work //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif and work well //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
egg
again, im not the only person with problems... but im sure your head wasnt out of your *** far enough to see that. if he was such a great business guy why wouldnt he stand behind his products?
If you would look he has worked with everyone who has had a problem to make it right.Maybe if you weren't such an *** about the situation you might have gotten different results.I mean even you said when you talked to him things got worked out.Don't you have an alt right now that you haven't tried yet?
i have an alt that i didnt want in the first place... i requested my refund before he sent that one back to me. and there was no way i was going to waste more time and money to find out that one was a failure too... i even told him that... i wanted a refund because flat out he could not give me what was promised... out of all the alts he sent me, they did LESS output than my stock alt... and things were worked out in the begining, but again, this was when i was working with him politely to try and settle it. he could not settle it and this is what it boiled down to. i still dont see why you fail to realize this.
we had an agreement, dominick could not fulfill his end of the agreement. what is so complicated about this? //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
200 @ idle!?!?! You bought a home generator!?!?
Are you sure its 200 at idle????Thats awfully high.//content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
Maybe not. From the site:
Q: What RPM does the alternator charge at?
A: The alternators will charge at idle.
Q: When does the alternator put out 14.6 volts?
A: It will put out full voltage as soon as the alternator cuts on and will remain around the same voltage throughout the RPM range
Q: Is 200 amp the maximum output?
A: The alternators will put out a minimum of 200 amps but not more than 215 amps, unless you purchase one of our higher output alternators.
Did I misread/misinterpret? Or is it really 200 amps at idle?
What do you mean less output then stock?Do you mean at idle or overall?DId you have it tested?Was it tested on the vehicle?
I get it you ordered your alt he shipped it.It didn't work so you sent it back he got it working and sent it back to you.What about the part where it looked like it had set in water for a year?Didn't you say the roads where salty or something to that nature?
dude, this has all been discussed in the other thread... take doms **** out of your mouth and get over it...
the roads were salted once when it was on the car (again, hard for it to get that much exposure when it spent so much time inoperable and off the car...
and by less output than stock, i mean just what i said... less voltage and less current than the stock alt, both at idle and at driving RPM.
Maybe not. From the site:Q: What RPM does the alternator charge at?
You asked what rpm does it charge at?The response means that you will get output at idle.You should ask what rpm does FULL output occur.
The alt always puts out 13.8-14.6 as soon as it cuts in,that is the voltage not amperage.Its how many amps it puts out at idle that you should have asked.
The maximum out put at 200 is what it is rated for at 2000 rpm engine speed, not at idle.Ask for idle and full rpm output.
yes you misinterpreted it. that is 200A at cruise. your idle is probably around 80-100A
edit: btw, im with hoss. i have seen too many things about iraggi to ever give him a dime of my money.
Jeremy M
Jeremy M
Moxee, Wa
IgnoreMe
