I could sell you my alternator off of my 04 dodge neon, its a 200amp iraggi direct bolt on. It was on my neon till I retired it it has approx 3,500 miles on the alternator.I have a 02 dodge neon SXT and i haven't been able to find an alt, well i did but he wants 650 bux for a 200a @ 2000rpms and 160 @ idle. right now i'm running 1 bxi2006d and a alpine mrv-f450. or if anyone has one used that they're not using PM me plz.
What!You have an Iraggi alt and it works?It can't be so!Hoss had me believe that Dominick was a scammer and only out to rip everyone off like he did to him.I can't believe you bought one...............I could sell you my alternator off of my 04 dodge neon, its a 200amp iraggi direct bolt on. It was on my neon till I retired it it has approx 3,500 miles on the alternator.
pm me if your interested.
egg
My shit works just fine.I guess its your personall experiance.Maybe a bad one but it isn't a scam.And I don't see him telling you he knew it was broke before he sent it to you.If he did he still sent you another one right.If it was a scam he would have took your money and said FU@K YOU what you gonna do after the first alt.***** all you want but it ain't a scam!He has been around just as long as most of the other companies that make HO alts so I don't think he's scamming anyone.Does shit happen,is his CS a little slow,YES.But he has tried to work with you on this whole situation.He doesn't HAVE to give you a refund.
What!You have an Iraggi alt and it works?It can't be so!Hoss had me believe that Dominick was a scammer and only out to rip everyone off like he did to him.I can't believe you bought one...............J/K
again, im not the only person with problems... but im sure your head wasnt out of your *** far enough to see that. if he was such a great business guy why wouldnt he stand behind his products?What!You have an Iraggi alt and it works?It can't be so!Hoss had me believe that Dominick was a scammer and only out to rip everyone off like he did to him.I can't believe you bought one...............J/K
If you would look he has worked with everyone who has had a problem to make it right.Maybe if you weren't such an *** about the situation you might have gotten different results.I mean even you said when you talked to him things got worked out.Don't you have an alt right now that you haven't tried yet?again, im not the only person with problems... but im sure your head wasnt out of your *** far enough to see that. if he was such a great business guy why wouldnt he stand behind his products?
200 @ idle!?!?! You bought a home generator!?!?
Maybe not. From the site:Are you sure its 200 at idle????Thats awfully high.//content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
You asked what rpm does it charge at?The response means that you will get output at idle.You should ask what rpm does FULL output occur.Maybe not. From the site:Q: What RPM does the alternator charge at?
A: The alternators will charge at idle.
Q: When does the alternator put out 14.6 volts?
A: It will put out full voltage as soon as the alternator cuts on and will remain around the same voltage throughout the RPM range
Q: Is 200 amp the maximum output?
A: The alternators will put out a minimum of 200 amps but not more than 215 amps, unless you purchase one of our higher output alternators.
Did I misread/misinterpret? Or is it really 200 amps at idle?
yes you misinterpreted it. that is 200A at cruise. your idle is probably around 80-100AMaybe not. From the site:Q: What RPM does the alternator charge at?
