HELP Engine noise/ground loop
SethPhillips
I'sa Playa
ok so all i did was move my ground for my 2 amp's and cap.. and now i have terrible engine noise... i moved the ground EVERYWHERE!! tried new rca's the only thing that worked was a ground loop isolater
but now everytime i tun my headunit on my speakers pop really quick and i can here alt wine!!!!
please help
LOL no replies huh. isolators work somewhat. check ur ground points with ur DMM multimeter if it read 0.1....... or whatever thats a good ground point if it read 1.0..... bad point. whereever u find that point sand the paint off and and clean with alcohol or something. then use a star washer and bolt that ***** down.. are you grounding the amps seperately? if so where are they grounded to? i like to use a ground distrobution block if i have 2 amps or better.
ok i have my sub amp, cap, and 4 ch amp grounded together.
by the way i am a certified M.E.C.P. installer ijust am brain dead on this one......
ive tried new rca's new headunit its GOT TO BE THE GROUND. i have yet to check it with my DVOM.
here are the symptom's
with ignition on car NOT running. my speakers sound like im amplifying static.
and they pop. when i turn up the sound it sound's like its clipping.
with the car RUNNING. bad bad alt wine!!!!! and all the other stuff i mentiond
i have tried other grounding points and have gottin the same thing!!!! but like i said i have yet to messure my refrance with a dvom
do i take my neg. lead to the batt neg and test my ground with the pos. lead??
thanks
Hello!I'm in France and I can't register on Hifiengine for unknown reasons and i need to download the service manuals for Blaupunkt Baden Baden...
Then I don't really seen the need to run a ground directly from the alt, but given your situation, it can't hurt.
24
162
452
SethPhillips
I'sa Playa
SethPhillips
Northern Utah
SethPhillips
    Jun 1, 2024
    May 31, 2024
