Help designing box for Obsidian V3's
Da64u
I purchased 2 12" Obsidian V3's and I'd like to build a ported box 2 cubic feet per sub tuned to 33 HZ.
Recommended enclosure info:
Ported ~ 1.75 to 2 ft^3 @ 32 to 35 Hz
Anyone use Obsidians before and know the kind of boxes they like?
I was just going to use the RE box tool to make things simple but I'm unsure of port surface area and length.
The only info they provide is:
http://www.stereointegrity.com/images/Obsidian/Technical/Recommended%20Port%20Surface%20Areas.pdf
Which doesn't make much sense, I don't think they are very clear in what they are trying to say.
Can someone give me some tips on filling out the blanks?
RE AUDIO - Box Calculator
I was starting with 33wx14hx22d but I'm unsure of square port width and square port width 2.
Thanks..
Download torres calculator ...re one blowwws
Either calculator is fine by me, but I just don't know jack when it comes to ports. I just know what size I need the box, and that I'd like to tune to 32-33HZ no more than 2 cubes per sub after displacment. Just don't know how long, and wide to make the ports and what the surface area is supposed to be..
Are you using a 4"aero?
13-16 square inches per cube for a slot port.. 8-11 is usually good enough for an aero. Port per cube isn't the best way to calculate port area, but it will get the job done.
when i ran my oas. i did 4.65^3 net @33Hz using 2 4" aeros. those things got crazy low and decently loud. still have the box no carpet or finish work done as i change subs like underwear at times.
what amp are you using to push the subs?
anywhere from 3.5 - 4 net tuned to 32-35hz would do fine
Also I'd use 1 6" aero vs 2 4" for efficiency purposes
AQ2200 or Hifonics 2200.1 if I can't find the AQ2200. Is this better? Is my port per cube too low?
I'm not going to make my box pretty either lol
Da64u
Da64u
Fort Lauderdale, FL
FadedSpy
