help clarifying strapping amps
bonesninja
i know how to strap the amps but i could use some clarity on what exactly the wires labeled 1, 2, and 3 are connected to in the following diagram....for instance wire 1 is connected to which terminal on the top amp?
Since the two + & - terminals on the amps are connected internally it doesn't matter which you connect to externally. Wire 1 will run from Master amp + (either one, it doesn't matter, they're both connected internally) to sub +. Wire 2 will run from sub - to Slave amp -. Wire 3 will run from Master amp - to Slave amp -.
i got some clarity from IA...... sub + to master amp +, sub - to slave amp +, then jumper from master - to slave -
bonesninja
bonesninja
Lima, Ohio
bonesninja
Mike Mccabe
