Help choosing battery
1baller
Turning On Your Alarm
im running 2 15'' L7's /hk4000d/5farad cap and got a reg battery of 750cold amps and 935 cranking amps. my voltage drops between 10 and 12.7 every 2sec im currently running a 4gauge but after listenin to u guys im gettin 0gauge power and ground. i need a good quality battery that will stop my voltage dropping between $130 and less. if it still continues after that ill do the big 3.
$130 or less?
Do the big 3, the zeron gauge wire is gonna help more than anything...Eh. 130 or less? Maybe find a Red top Optima to replace your reg.
Costco has some cheap Optimas. if you guys have a costco down there. you should switch your wires first tho i bet thats the reason why your volt drops so much
1baller
1baller
Los Angeles
Newport
