Sq, will be time aligned and as best of on axis as I can manage for my first fiberglass pods. Probably crossing over around 1k.What's your goal - SQ or output? Location and aiming? Your expected crossover points?
Sent from my SM-G900V using Tapatalk
I'm capable of crossing over anywhere between 1k-12khz for my highs so if u have any recommendations I'm open., I want it setup so my 6.5 is strictly midbass and the wide banger covers the rest of the frequencies. So if there is a speaker that'll do like 800-15k thatd be what I'm looking forHmm, I haven't found a 2" driver I've really liked and I have a few. Lots of nice 3" drivers but that is too big for 1kHz.
Thanks for the offer but I don't want to run coaxialsI got some image dynamics 4 inch ctx coaxials for 40 shipped and paypal fees included, rated 50 rms but will easily handle more than 100 watts if on a crossover at 1khz. Had it high passed at 125hz at -24db and it handled everything a ppi 600.2 could give it.
Will handle 125hz and up easy, especially if in an enclosure so you can even cross at 315hz if you want. The tweeter is pretty smooth and airy. Can be pretty good with eq and clean power. Tweeter positioning is adjustable as well
The only coaxials I've really looked at were the mirus by hybrid audio. Thanks for th recommendations though, I'm looking into em nowTypical widebanders cover 300-500hz all the way to 5000-20000hzThere's only 2 that I know of that can do to 20k well. They will need to be fairly on axis.
HAT L3SE 300hz-20k
Audible physics RAM 2 400hz-20k
Both will need the required airspace
Btw a point source coaxial is great. If it can be bi-amped
Not necessarily laid back treble, I just want it to sound as accurate as I can possibly get it toCDT's 2" mid-tweeters do what you want and I've run them active on 145Wx2. I tell everyone to expect laid back treble. Is that what you want?
You dont want accurate, you want more detail than flat response. You want a nice sound quality curve if you actually enjoy music. Flat and accurate is boring and mainly if you compete in RTA in mecca. You want highly detailed, and vibrant sound thats smooth and buttery. Gonna take some processing to do so.Not necessarily laid back treble, I just want it to sound as accurate as I can possibly get it to
Call it accurate or detailed, getting the full range of frequencies isn't enough in my experience. I recommend using a small tweeter for brilliance and air.Not necessarily laid back treble, I just want it to sound as accurate as I can possibly get it to
One of the top cars at finals last year had a 10in sub in each kick and a set of 4in illusion coaxials in the pillars.The only coaxials I've really looked at were the mirus by hybrid audio. Thanks for th recommendations though, I'm looking into em now
