Help buying an amp
fofo302
Hello I just recently got 2 Pioneer TS-SW2541D 10" subwoofers for my truck, I wanna Buy a hifonics Brutus Series Amplifier But im Not sure which one to buy, Can someone help me out please?
Pioneer TS-SW2541D specs:
Subwoofer Size 10"
Dual Voice Coil No
Impedance 4 ohms
Peak Power Handling 1000 watts
RMS Power Handling 50 - 250 watts
Woofer Surround 3-Layer Fiber
Woofer Composition IMPP composite
Sealed Box Volume 0.35 - 0.70 cubic feet
Ported Box Volume 0.35 - 0.70 cubic feet
Sensitivity 87 dB
Frequency Response 20 - 1 k Hz
Xmax (millimeters) 6 mm
Top Mount Depth 3"
Hifonics Brutus Series Amps Link
Thanks
Do you think this amp: Hifonics BXi 1206D, is too much for both subs? is it ok?
Specs:
Amplifier Class N/A
Number of Channels 1 - Mono
RMS Power (4 ohms) 450 watts x 1 channel
RMS Power (2 ohms) 900 watts x 1 channel
RMS Power (1 ohm) 1200 watts x 1 channel
Bridged RMS Power Not Bridgeable
Peak Power Output
Minimum Impedance Unbridged 1 ohm
Minimum Impedance Bridged N/A
THD at Rated RMS Power
Speaker Level Inputs Yes
Amp Preamp Outputs Yes - 1 pair
Built-in Crossover Yes - LP
High-Pass Crossover Frequency
Low-Pass Crossover Frequency 35 - 250 Hz
Subsonic Filter 15 - 50 Hz
Signal-to-Noise Ratio >95 dB
Channel Separation N/A
Bass Boost 0 - 18 dB
Bass/Gain Remote Yes
fofo302
fofo302
mexico
fofo302
NorthFramingham
    Jun 30, 2026
