Help Building Athird Row Eclosure For 2 15" L7s
zerocarpileup
The Birds The Word!!!!!!!
Hey guys im new to this site and absolutely loving what i see,
I need help building a box for my 2002 Escalade to fit behind the third row.
im not looking to go too fancy but id like to see what ideas you all have for me.
im trying to fit two 15" kicker L7s bind the third row. i see i dont have much room to work with so i guess im going to have to build across the whole back.
i have a pic of what 3 12 solo's look like but i could use some specific instructions.
Please Help!
i was never impressed with the size of the box that kicker squares go in, but if you can get each of them in 6 cubes, they slam as hard as any sub. the boxes are just too big for my taste. looks like you have limited space. my recommendation with those subs, would be to port just 1 in 6 cubes, if you can't fit them both. the l7 15 is an impressive sounding sub in a nice big box. if you start dropping down too low, in an attempt to fit 2 of them in a smaller space, you will lose output. not the most efficient subs around. i have done L7's in similar vehicles, and if you can get the 6 cubes for each sub in there, you won't know many people who can get louder than you.
Thanx for the input guys, but im getting a bit confused with all the different specs. were talking sealed enclosure if that makes any difference on cubes.
does anyone have a diagram i can see,:stuck:
Thanx for the input guys, but im getting a bit confused with all the different specs. were talking sealed enclosure if that makes any difference on cubes.does anyone have a diagram i can see,:stuck:
i would not use those subs in a sealed box.....if you really want to do 15"s Sealed, look at maybe the CVR's if you like Kicker. I would rather spend a bit more money and go with Soundsplinter RL-p's or Stereo Integrity Magnums..the last model not the current model.
ok, so you say i should go ported, what are the pros and cons of ported vs.non-ported, given the information on the style of box i want, similar to the pics i posted.
i will go measure and post the specs of the space behind the third row
ported is a more effeicient way to get loud if you can sacrifice the space. if you need a small box sub, go with a sub meant to be in a small box. kicker is not the way to go if you want small and ported. the 15 kicker l7 needs 5, preferably 6 cubes to reach optimum performance. other 15's like a much smaller box. some do well in even 3.5 cubes ported. some 15's do well in 3.5 cubes sealed, but require 6 ported.
zerocarpileup
zerocarpileup
on1wheel01
