Help bridging my Soundstream 700sx
chrisspliff
I just got a used soundstream 700sx from ebay
I am bridging it to run my triple loaded sub box. I noticed that it only uses one rca from the headunit. I can completely remove the left rca input and still get my subs to pound in bridged mode.. Is it normal for a bridged connection to run off only 1 rca?
I tested both the rca's and they both have signal and work but only on the right input of the amp
I tested it further by putting the amp in stereo mode and used both the rca inputs. They both worked.
Is this normal?
Just got hold of a manual and it said only the right input is active in bridged mode. Never mind answering.
Thanks
The manual already answered your question, I see.
If at some point you have some questions to which the manual does not offer answers, feel free to ask.
If I understand you use it do drive three identical subs. What is the impedance of each sub ?
You're driving them in parallel, I suppose ?
chrisspliff
chrisspliff
So. Cal
azvrt
vegang
vegang
