Help Box Design on 15's Ported
agrimm034
I need some help on getting some demensions on a ported box. Im putting 2 Xplod 15" woofers into a ported box. It does not matter how the port is weather its round or rectangle which ever is easiest. Feel free to call me if you can help me out. (304) 531 - 6112 Heres the info on the subs...
D(inches) - 12 1/2
FS (HZ) - 25
Qts - 0.62
Qes - 0.69
Qms - 6.35
Vas (Lit) - 110
Vas (Cu.ft) - 3.88
Lvc (mH) - 2.24
Xmax (mm) - 5.5
Xmax (inch) 7/32
BL ™ 14.8
Enclosure vol (Net) - 47.6 Lit (1.68 Cu FT)
Thank you!!!!!!!!!!! Im no expert at this I need some help!
1st go into your trunk and measure all the available space you have to work with.
then go here - RE Enclosure Calculator
adjust the lengths based on what you got available and to your desired volume and tuning.
once you're done there's a cutsheet at the bottom.
I'll get the deminsions out to you tomorrow. I've got a sealed box I bought from HIFI sound connection and its ok but it's not what I want. I want to build (2) identical ported boxes to put in the trunk for (4) 15's xplod 4 ohms wired to a 1 ohm load on a 2000w hifonics brutus amp
I'd like 4 15" FI BTL's but for how much the 15" xplods cost and what I have herd with my own ears, there clean and do what I need them to do until I get some more money to upgrade to a better sub.
agrimm034
agrimm034
Mason, WV
agrimm034
