Help! Amps won't turn on!
Ajs DrtyRig
Im_A_Drty_Boy
Hey guys,
I've just installed my 2 new amps:
An Eclipse PA4212 and an Alpine MRD-1005
Everything installed perfectly, but one thing wrong...
The amps won't turn on!
I'm using mostly KnuKonceptz wires and distributors, i'm using a Power Distributor and a Ground Distributor.
All wires and cables are brand new..
Any ideas as to why they may not be turning on... please reply, thanks alot!
-Ajs DrtyRig
Hey, i just checked it all with my DMM, and from the battery out, i'm getting the power, but when i go to the back of my car (where the amps are) theres no power from the cable, i think i may have a bad ground, because thats all i can think of... my fuses are all fine, i just checked them all too.
Any other ideas until tomorrow when i find a new ground, let me know!
Thanks guys!
Hey Guys,
After finding a new ground and still having the same problem... i thought about how the car is getting it's current...
I then realized that i have a KnuKonceptz Positive battery terminal, and the KnuKonceptz ALSO sells a negative terminal designed to do the same as the positive...
Should i go ahead and buy the negative terminal too and use that as my ground for the amps?
Let me know if you think that will work/fix my problem
Thanks!
Ajs DrtyRig
Good way to tell if you are getting power is to do the "spark test"
Just remove the fuse, plug is back in and if it sparks the curcuit is live.
You can also do this with the ground wire on the truck floor to see if you have a good ground.
Awesome, I went to check the other fuse under the hood and the power cord had fallen right out, i didn't tighten it in...
All is working perfectly now, thanks again!
-Ajs DrtyRig
Ajs DrtyRig
Im_A_Drty_Boy
Ajs DrtyRig
Marin County, CA
supa_c
