Help ! amplifier giving very soft muffled sound
hi i have a 5 ch amplifier which i use to power all my music i took out the amp to make an amp rack for it but when i reinstalled it i wasnt getting much sound at all unless i turned the head unit up to max and still that was very soft compared to its usual out put also it sounds very muffled any help i checked the fuses, ground and pre amp but it still isnt working
thanks guys i pod test worked the amplifier is working its the deck that seems to be giving trouble using the system through my phone directly into the pre-amp for now //content.invisioncic.com/y282845/emoticons/nerd.gif.c6fa51ddf7ff75f1c0371fbc648f70ae.gif
Look on the deck to see if there's a sub setting also change the RCA to the sub amp from the deck what do you have for a pre amp ?
Bling Bling Boy
Bling Bling Boy
Brooklyn NY
mylows10
michigan born
    May 14, 2026
michigan born
    May 14, 2026
