Help A Noob Out! Please :)
:\ they was hard to find cuz of being discontinued, and i heard they would withstand a lot of power and was decently cheap so I got them thinking they was good :\
Why do some people put their subs inside out tho? Like some have the magnet inside the box and some have it out in the air.
Got another question! I have 2 12" KENWOOD subs, are they underperforming subs? I can't use my amp all the way I don't think without blowing them. Here are the specs. Also, my Volf's out bump those kenwoods. (probably because I can put all power to my volf's
Subwoofer Series Performance (Kenwood)
Subwoofer Size 12"
Peak Power Handling 1200 watts
RMS Power Handling 400 watts
Voice Coil(s) Single
Impedance (Per Voice Coil) 4 ohms
Frequency Response 34 - 300 Hz
Sensitivity 85 dB
Xmax (millimeters) 15.1 mm
Subwoofer Design Round / Circle
Main Cone Color Black
Woofer Composition Polypropylene
Woofer Surround Urethane
Subwoofer Grille No
Re-Cone Kit Available No
Recommended Enclosure Specifications
Recommended Enclosure Type Ported / Vented
Sealed
Minimum Sealed Box Volume 1.25 cubic feet
Maximum Sealed Box Volume 1.75 cubic feet
Minimum Ported Box Volume 2.0 cubic feet
Maximum Ported Box Volume 2.5 cubic feet
Top-Mount Depth 6-1/4"
Cutout Diameter 11"
Shallow Mount Installation No
Dirtyrandy I got the dimensions if you could get me a box design that would be awesome.
12" tall, 35" wide, 38" deep
wow man if you think the volfs are everything you have soooooooooooo much to learn! and also if they where to see anything close to 500 watts they would fail in seconds, build a decent box for the kenwoods there are a better speaker.
I want to I Love my kens but I can't turn my amp up all the way or I feel like they are going to blow. Any reason why my lens can take my amPs heat but my volfs can?
Alright thanks that does help, I always thought higher RMS means better and louder subs.
It's a common misconception, but it's not necessarily true. For example, Sundown sells an 'E' series subwoofer rated for 400w RMS - and they get reviews that mention that they top some of the Type Rs. (600/750w). It's just about the build of the sub.
Can anyone answer all of my questions tho please? And I guess randy isn't Gna help me out with dimensions :\
Bump help please //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
FYI - don't bump so often. I'm pretty sure it's against forum rules to do it more than once in a 24 hour period..
[quote name='Quick']Dirtyrandy I got the dimensions if you could get me a box design that would be awesome.
12" tall, 35" wide, 38" deep[/QUOTE]
Sorry, I am out of town for the next ten days without my computer. Maybe quicker to have @Buck design you one. Think it's $5-10 for a design. You must have the shortest trunk ever at 12 inches tall
Quick
Quick
Texas
Quick
