Help a noob make speaker choice.
I'd get a better amp - look used or bump your budget for the amp up a bit. If you have to, you can get a better amp now and then get some Pioneer Rev coaxials or another good set of coax's for the time being until you get some more $$$ for components.
So why not just get a cheaper set of components to hold me over until I can afford better ones? It's been explained to me that cheap components are usually better than high-end coaxials. Or am I just confused?//content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
Considering several component sets have tweets that are able to be coaxially mounted, the line gets blurred...would you call a cheap component set better than a set of Boston Z6's with the tweet mounted in the center? //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
All depends on your setup, and how you're aiming the drivers...sometimes coaxial mounting works better, sometimes it doesn't. Only way to know is to try both ways.
It looks like you have a $200 budget, right? If that's the case, you simply don't have the budget to do a decent amp AND decent components right now. However, you do have the budget to get a decent amp and then get a set of decent coaxials to use temporarily. Like the other poster suggested, with your budget, you may really want to look into used.
However, if you go new, here's what I'd suggest...
Amp:
http://cgi.ebay.com/HIFONICS-ZEUS-ZXi3406-2-3-4-CH-300-WATTS-AMP-NEW_W0QQitemZ290045522831QQihZ019QQcategoryZ4950QQrdZ1QQcmdZViewItem
Decent little amp that'll put out 150wrms x2 @ 4 ohms - that's enough to sufficiently push most sets of components Price here would be $145ish shipped.
Temporary speakers:
http://cgi.ebay.com/ROCKFORD-FOSGATE-P162C-6-1-2-2-WAY-CAR-SPEAKERS-6-5_W0QQitemZ300043467471QQihZ020QQcategoryZ18799QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Decent little speakers. Go with these if you can bump your budget up by $15-20. I've been running them for a year and a half now. I'm getting ready to go with comps, but I've been very happy with their performance.
If you can bump your budget by $50 or so, you could go for the Revs. If you can swing $300, you can get it all over with right now and get a decent amp and some decent comps. It's up to you. If you want some decent sound now and you have a strict limited budget, my suggestion is a decent amp with some makeshift speakers. If you're going to have the $$$ soon, I'd suggest holding out until you do.
Amp:
Temporary speakers:
Thanks for the advice!//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
What would you reccommend as a good entry-level component?
Swoop41
Swoop41
Mississippi
Gary S
Mike Mccabe
