GP tip: Are you getting the most out of what you currently have?
Solving insufficient grounding:
To some of you this may be novice, but in my time I have seen this method used rarely.
Start your car and use a dmm to read what that voltage says directly off the front battery.
Lets say it says 14.4v (car running on the underhood battery, stereo not on)
Now go back to the rear battery, or if no rear battery directly to your amp.
Touch the positive of the dmm to the positive post of the battery (or positive input on amp), and then take the negitive wire on the dmm and touch the current ground you are using, if it says anything less than what your underhood battery says (14.4v in our example) than you have insufficient grounding.
So lets say you do this, your underhood battery says example 14.4v, and when you go back to the read the rear voltage of the battery/ and or amp it is says 13.5v, you are loosing out on almost a full volt of power, and in the 12v world, 13 to 14 volts can be a significant percentage.
So now its time to locate a new ground, again Using the DMM, holding the positive on the dmm to the positive on battery/ amp input,
With the negitive on the DMM search for a new grounding location,
once you find a ground that reads 14.4 you know your in a spot that will discharge properly.
This method ensures your voltage is lined up perfectly with the underhood battery, one of the few steps to ensure the best in voltage stability and getting the most out of your equipment.
So what are you waiting for! Go see how your voltage lines up from front to back and let us know your results!
