head unit install
  • Thread starter Unregistered
  • Start date
  • Replies 3
  • Views 811
as said above, check the color codes, but if your deck is sony pioneer kenwood panasonic jvc etc. the color of the memory wire is yellow, it goes to a constant power source.....directly to the battery, there will be a wire in the dash for this, and the red goes to a switched power source not the battery as stated above
Pull the head unit out, and at the harness use a test light to check 12v, ground, and Accessory. If all three are good, you have probably...
7
Youll need a Honda Civic reverse radio wiring harness and 20 toyota radio wiring harness ...match colors of wires and shes ready to go...
Installing a Jensen CAR710W head unit in my sons 2013 Volkswagen Golf. No steering wheel controls. I purchased the XSVI-9003-NAV wiring harness...
One or two, they are still subwoofer outs and are mono summed signals from both left and right. Even the 2 RCA subwoofer pre-outs on the 2nd one...
341
There are a couple of options. You can use a marine bt unit. They come in the size of a hockey puck and can mount anywhere. This is the marine unit.
531
Guest
gregj9
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
Latest topics
