hdc3 18 box
If you keep those dimensions exactly with a little bracing and a double baffled top plate you would net a little over 7 cubes....you are prob going to want to run three 6" Aeros in order to have enough port area.......Three 6" Aeros 16" in length would give you about a 36hz tuning and 11" of port area per cube....If this is in an SUV of some sort I would do SUB UP & PORTS BACK............good luck
Double the baffle and you have 8.23ft^3 before sub and port displacements.
-.25ft^3 for sub
-.9ft^3 for three full length(17") 6" aeroports
-.1ft^3 for bracing
7ft^3 net...but with a 40hz tuning.
wat about if i do 4 4in ports??
-.25ft^3 for sub
-.1ft^3 for bracing
i read sumwhere the disp for the 18 is .34
Audio4ever
Box Chevy Boi
Audio4ever
Maryland
bgowdy
