HDc3 12 Box recommendations?
Cool, thanks for the info.
Not sure running a few ideas through my head. More than likely a Sundown
1500d at .5 ohms. so 2000w to 2200w I suppose.
2.0 works well for me, I could run (4) of them and have the proper space.
i have mine in 2.75 a piece and its a little too large.. making the response a little too peaky imo. 2 would probably be good for a trunk car.
Although from what i'm seeing from them i'd consider a touch more power. I'm running about 4.5kw to the pair and its enough to get them to bottom out @ tuning frequency..(well, **** close as i didn't actually let them bottom) so anyway 4kw is way more than enough. If you can swing say a kx/zx2500 or something that would probably work well.
Although i know how expensive it gets when you start stepping above the 2kw range.. adding batt's and alts and all that.
I would love to do a pair of Orion 2500ds, but im iffy about buying them used. I have had (4) Orion amps and never had one problem out of any of them, (3 used) but didnt want to push my luck.
I really like Sundown, but im thinking the AQ 2200 would be a better match per sub. I had planned on doing a pair of 15s in 8 cubic feet, but consider (4) 12s in that space as well.
Its looking like the 15s would be the better choice at the moment.
tez4life
Premium Member
Premium Member
tez4life
Mobile, Al
tez4life
vegang
vegang
