Having voltagw issues
cows0136
ohio
I have two batteries and a 1500 watt amp. i tested both batteries and they are 12.6v with the car off and i have a 270 amp h/o alternator. well when my bass is hitting the volume at 10 and my heater on setting 2 out of 4 my voltage is dropping to 13.5V i thought a second battery would fix lights it didn't so i got my high output alternator and the lights are still dimming and the voltage is pretty low at such a low volume what is going on? im driving a 95 grand prix
The shop when they put it in ran 4gauge and yes iv done the big 3 u can't install a h/o without doing the big 3 u could but it would **** up the wiring
You shouldn't be getting any dimming period with a 270A alt. A 1500w setup at the most will pull around 110A of current and that is full tilt on a test tone. What kind of alt do you have?
Mechman alternator The shop ran 4 gauge wiring i don't know if doing the big 3 in 4 gauge wiring would have any effect but i don't know what the hells going on
I think i located my issue but need some advice. Before i had the new alternator put on my belt never squeaked well after i put it on the new belt squeaks (well after the shop did) it squeaks on take off then stops when i get going. but also my lights get brighter and my heater fans speed up (i would assume means a loose belt I have a serpentine belt.) i don't know much about cars soo any advice would be needed the **** shop that put it on for me said its as tight as it needs to be so im going to have to pay another mechanic to tighten the **** thing (just so i don't over tighten it)
Okay well the belt is fully tight so i have no idea why my lights are dimming and my rmp meter is dipping. i'm so lost and pissed iv put about a grand it to try and help with this and nothings working not deep cycle batteries not a a 270 alternator ugh
https://www.caraudio.com/threads/all-bnib-focal-fdp-4-600-ds18-exl-p2500-1-sundown-audio-sfb-1000-4d-350x4-4ohms.614462/ :)
18
Seems kind of stupid to prevent helping others with advice on equipment from Amazon, doubt that Amazon is preventing this either. Pain in the arse!
14
921
I would Double check the LC2I settings also and make sure all wiring is secure and not loose as well.
Update I have been playing with the silver flutes and just can not get what I want out of them. I spoke to stereo integrity today and ordered a...
I'm not a big fan of Brand X personally. My car idles at 500rpm and my Autotech didn't turn on until 650. I sent it back and he redid it to turn...
852
cows0136
cows0136
ohio
akheathen
    May 18, 2024
    May 16, 2024
