having many small ports same as one big port?
oh okay i was not aware that was possible, does it sound the same though its essentially the same thing just inside out? or is there other lenths and what not to be how i want it?
Its exactly the same as having it in the box, except that it doeskin take away from your boxes volume. You can also do ports partially in the box/ partially out of the box and account for how much displacement the port has that is physically inside the box
Cool so does this seem right to you? If so im planning on building the box with the sub facing up and the external port below it aiming towards the dash on the floor. Would you reccomend an aero port or just a rectangle flat against the floor? Saving space would be prefferable.
Either work, an aero may be easier for building being as it will be external. and as far as firing it foward towards the dash im not sure if that will give you the best results or not you'd have to hear from someone that has a similar setup since every vehicle behaves differently. I know some truck setups fire the port rear towards the back wall
C1500martin
C1500martin
Cali
phemps
michigan born
    May 14, 2026
michigan born
    May 14, 2026
