have about 500 to spend on a sub setup HELP
1. what about an rli10
2. is there any other amps you can recommend besides the 1606
1. It wouldn't be a bad choice at all, IMO.
2. Sure thing: Infinity 611a or 1211a, JBL GTO601.1II or GTO1201.1II, Pioneer PRS-D1100M or PRS-D1000M, Memphis 16-PRD500.1 or 16-PRD1000.1, Kenwood eXcelon KAC-X10D or KAC-X1R, Phoenix Gold Xenon X400.1 or X600.1 or X1200.1 (if you can find them) to name a small handful that could fit into your budget. Some of those are 1 Ohm stable, some are not, so be sure to do a little homework on the sub+amp combo you're wanting before buying.
ok what if i got an rli d2 and this amphttp://www.sonicelectronix.com/item_6521_Hifonics+BXi+606.html
1 ohm stable so it will work puting out 600 watts rms, would that be fine or should i get something more powerful
I say get somthin you can use in a bigger system..
if you run that you will need a bigger amp if you ever add more to you sub stage..
thats how I do anyway.. always leave room to add more ish..
zyklonb
zyklonb
new york
nauc
