Hatch Help
g6ryder
Alright today I bought a '13 Chevy Sonic LT Hatchback. Not my primary vehicle it's the wife's but time will be split driving it. Question is what works better with a hatch port/box/sub orientation? Will be keeping this system light. 1 12" most likely in a 4th. Already know all gear that will be used. I have the 7" Chevy "my link" unit that will be staying factory may upgrade components later I will see how they hold up. RF 360.2 will be used for processing since I already own it.
Most of the time same as trunk sub and port back or sub back port side
Good luck fitting a fourth on there small hatch
Also the Chevys alt only charges when you are on your brakes driving it doesn't get above 13.8 iirc but I think it is a 130amp alt on that little 1.4. Be careful on amp selection cause the car will charge to 15.5 occasionally some amps don't like this
I ran 1500w in my Cruze without big 3, extra batt, stock everything without much light dimming
g6ryder
g6ryder
Claremore, OK
g6ryder
